I am practicing CAT7 tourniquet. It is quite ok on hands - I apply tourniquet until oximiser stops sensing pulse on my finger. However, oximiser does not fit my toe. How do I check I applied sufficient pressure on my legs? I do not trust trying to check pulse by fingers as they often do not sense that the pulse is still there
Thanks
Practicing CAT7 tourniquet - how check legs?
Re: Practicing CAT7 tourniquet - how check legs?
First aid... You tighten it up till blood stops leaking... Nothing more complex than that...
5cm above the wound regardless of single / double bone compartment... If the first one is ft and bleeding still occurring place a second tourniquet 5cm above the first unless on a joint then you go above...
Ideally a pressure dressing & gauze should be tried first unless claret is shooting across the room
Unless its Hosing go with pad,dressing and pressure..... If it is bad enough to need a CAT wind it up until the blood stops.
TK's should only be removed in Resus or Theater...... ie not by you or me.
I think you'll find that if you're practicing until your pulse stops then you're not going far enough, after all a blood pressure cuff has to stop your pulse and I don't think you could use one of those as a TK.
And now we wait for a real medic to come along and tell us we're all wrong
ForgeCorvus wrote: ↑Tue Dec 12, 2023 7:21 pm Unless its Hosing go with pad,dressing and pressure..... If it is bad enough to need a CAT wind it up until the blood stops.
And now we wait for a real medic to come along and tell us we're all wrong![]()
When you do it tight they scream.....
It’s that simple.This last twelve months I’ve had a tourniquet almost daily at times,and what Andy describes is bang on.Yorkshire Andy wrote: ↑Tue Dec 12, 2023 6:40 pm First aid... You tighten it up till blood stops leaking... Nothing more complex than that...
Mad Scientist
Great to see you back Jansman!!
And nice to hear from you too!
