Gas bottle burner
greyman
Gas bottle burner
Post by greyman »
Been making these for a while and while doing a first burn to remove the paint noticed how it was basically a big rocket stove as the flames shoot out of the flue,
Decided to build a trivet for the flue out of rebar and give it a try,very impressed with how quick it boiled a full kettle
nickdutch
Re: Gas bottle burner
Post by nickdutch »
Thats unbelievably beautiful to be honest. Once I have the cash I was thinking of getting a few of those L shaped rocket stoves as they look like great fun and fuel efficient for outdoors cooking too.
greyman
Post by greyman »
I'd have ago at making one of these,you only really need an angle grinder and a drill.
Plus you get the added bonus of keeping you warm as they throw out some heat .
Devonian
Post by Devonian »
greyman wrote:I'd have ago at making one of these,you only really need an angle grinder and a drill.
Before anyone thinks Oh OK and takes an angle grinder to a gas cylinder, please, please, please exercise EXTREME care and make sure that the gas cylinder has been properly purged of its (explosive/flammable) contents. Else you risk causing yourself and other in the area life changing injuries (or worse!).
greyman
Post by greyman »
Yeah,what he says.
Purge the bottle first,here's a step by step its easy.
Depending on bottle type try and get a regulator and open the bottle to release gas/odour,I leave mine for a week .
After your week try and remove the brass connector on the top with a big spanner usually a good tap with a hammer will get it moving,if not hacksaw through the brass connector flush against the top of the bottle,once this is off fill the bottle with water,again I leave it for a week,but have filled and emptied twice and used straight away.
Please note I accept no responsibility if you go bang ,but I've done close to 30 of these and I've still got my eyebrows(no fingers,just my eyebrows) :shock:
REMEMBER SAFETY FIRST
AND DONT SMOKE WHILE YOUR EMPTYING THE GAS OUT.
probably forgot something,but hey ho
Wulfshead
Post by Wulfshead »
Don't forget that a nut on a gas bottle with a line cut into the corners of the flats undoes clockwise.
The water filling trick is a good-un, I use this method when making my forge bodies out of old gas bottles.
Wulfshead
Area 4 Coordinator
A jigsaw with fine-toothed metal cutting blades will also work........ Slowly, but more precisely then your average mangle-grinder.
greyman
Post by greyman »
ForgeCorvus wrote:A jigsaw with fine-toothed metal cutting blades will also work........ Slowly, but more precisely then your average mangle-grinder.
I use the 1mm discs forge,I know what you mean about the mangle grinder :D
I hate slitting discs full face screen if i use them i have seen / had several shatter
oh god just seen this do not copy this chap :roll:
https://www.youtube.com/watch?v=I2F7d8Y1jbA
oh and steel and steel also makes sparks never mind the fag in his mouth
