Thanks, I knew it would be a relatively simple process, plenty others have done it, I'm just being a nervous nelly. :oops:
roddas
Post by roddas »
Deeps wrote:Thanks, I knew it would be a relatively simple process, plenty others have done it, I'm just being a nervous nelly. :oops:
One thing i will say is if solar only you would be much better using a pwm ( pulse width modulation) type solar controller as they will maintain the batteries and keep them at peak charge ready for use, the other type is mppt( maximum power point tracking ) controller but you would not really benefit from this type of controller for the set up you are talking about
All good to know, thanks very much, I'm looking forward to finally getting it done.
Oh it's simple enough for the basics...
This is the identical panel I have on my workshop
https://www.photonicuniverse.com/en/cat ... clips.html
So that
And a leisure battery
Take your pick
And ohhhhh. 12v charging.....
Now the magic black box
2 wires battery + & -
2 wires solar cell + -
Other 2 your load ( your lights / 12v socket)
Mk 1 sheds now been demolished and panel movsd
viewtopic.php?f=38&t=12046
Wish I'd gone for a 60w or bigger but the 30w I'd adequate for running my shed and battery charging the numerous as and sas cells the kids desire ;)
I've boosted it up today off the mains since I had the tumble drier on in there shed has no mains power so lives off 12v
Within 20 mins it (110ah battery was full)
Pull a extension cable for the tumble from the kitchen..
I've got 12v lights 2x10w floods to light outside and a 1m strip of warm white and a 2m strip of cool white inside
And my budget inverter box is what it's running off giving me mains if needed
viewtopic.php?f=38&t=11070
Thanks Andy, it was supposed to be this years big project but its slipped right. We've not had a power cut in a good long while and there's an element of 'playing' but with a practical application. I'll run a shed light off it too, its something I fancy knowing. The other project is building a tandoor.
Mines a garlic nann and chicken tikka ;)
Yorkshire Andy wrote:Mines a garlic nann and chicken tikka ;)
My brother in law has done it and swears by it. Plenty of inspiration on youtube, doesn't look too tricky although I daresay there will be an element of figuring times and temps out.
If your wood firing it different woods give more heat / the way it's split / dampness ,,,,/ air flow
Had "fun" sussing the wood fired oven
Pete_59
Post by Pete_59 »
To go back to the solar discussion, one of the options for dealing with excess power is to heat water, there are 12V and 24V immersion elements readily available that will fit standard hot water tanks
Brambles
Post by Brambles »
Pete_59 wrote:To go back to the solar discussion, one of the options for dealing with excess power is to heat water, there are 12V and 24V immersion elements readily available that will fit standard hot water tanks
Yep, another thing on or list is to run hot water from excess energy produced. Our system is a year or two down the road so we are in the info gathering stage atm.
