2 Person Sleep System for Bug Out Situation
space.gamer
Re: 2 Person Sleep System for Bug Out Situation
Post by space.gamer »
Frnc wrote: ↑Mon Oct 03, 2022 3:40 pm My gut feeling here is ditch all three, and just get a decent sleeping bag from a more well known brand. You could just go for a quilt. Backpackers use them because when you lie in a sleeping bag, the comression under you renders the insulation near to zero, so you are relying on the mat. These quilts don't look like ones you put on you bed though. they look like a sleeping bag with a bit missing and no hood.
Bag or quilt, for the price of your three items £226 each you could get a more tried and trusted bag (Sea to Summit is a good make by the way, but I got a map case off them I couldn't open!). And save a lot of weight.
Here are some suggestions
342g, 5°C Sea to Summit £255
https://ultralightoutdoorgear.co.uk/spa ... eping-bag/
370g, 7°C Thermarest £240
https://ultralightoutdoorgear.co.uk/hyp ... eping-bag/
436g, 10° Sea To Summit £185
https://ultralightoutdoorgear.co.uk/tra ... eping-bag/
Again, thanks. I've actually struggled with picking a sleeping bag the most.
I'm thinking a bag will suit better than a quilt. Just knowing us, the cuddly feeling of a hooded bag is best.
I do like those bags you listed but think I'd rather have synthetic.
I fancy a Big Agnes Torchlight UL 20 (long) https://ultralightoutdoorgear.co.uk/tor ... eping-bag/ but they are very expensive. Perhaps a Big Agnes Buell 30 Synthetic Sleeping Bag https://valleyandpeak.co.uk/products/bi ... 8996781289 or Vango Ultralite Pro 300 Sleeping Bag https://www.gooutdoors.co.uk/15895517/v ... g-15895517 are better options, whilst not being quite so small/lightweight.
space.gamer wrote: ↑Mon Oct 03, 2022 4:08 pm
Frnc wrote: ↑Mon Oct 03, 2022 3:56 pm Those tent pegs might not be much different to the ones the Vango comes with. Again, you can save a few grams swapping things like that. I have a few ones similar to that, plus a few titanium wire pegs.
What rucksacks do you have?
You want about 50 litres (each) with good back system, light frame, and pockets. I use an old model Kelty Redwing. Another good make is Osprey. Rucksack shouldn't weigh much more than 1.5 kg.
The Pegs were pretty much an afterthought so no issue there.
Backpack-wise, I've got 2x 5.11 Tactical Rush 72 2.0 Backpacks (55L). https://www.511tactical.com/eu-en/rush7 ... kpack.html These are non-negotiable as I've just spend a fortune on these. :P
Fair enough. Those bags are a bit on the heavy side, so just watch your weight with everything else.
space.gamer wrote: ↑Mon Oct 03, 2022 4:28 pm
Vango is 1.35 kg. That's like 4 x heavier than the ones I listed! It packs down correspondingly large, ie will take up most of the main compartment of your rucksack, which has lots of small compartments. Your sack is 50l but the main compartment might only be 30. This sleeping bag packs to just over a foot long x nearly 10 inches diameter.
Don't be scared of down. I had one for over 20 years. Never had a problem. Very light and packs small.
The Big Agnes synthetic is also pretty heavy at 1.11kg for the regular. The other Big Agnes is down. expensive, but much much lighter. Comfort rated -7° for a bugout bag is overkill in my opinion. My system, honestly, probably comfort rated about 8-10°. Comfort rating is a lot higher than bivvy rating or survival. Comfort means you shouldn't keep waking up feeling cold.
Anyway, maybe weight doesn't bother you, but volume will. If it fills most of your main compartment you'll be pretty gutted, so think about volume.
This is synthetic, not hugely warm, but will pack very small and is light.
https://ultralightoutdoorgear.co.uk/mou ... eping-bag/
Or this one, warmer 414g
Another one, comfort 10°, 346g size L
https://ultralightoutdoorgear.co.uk/osc ... eping-bag/
space.gamer
Frnc wrote: ↑Mon Oct 03, 2022 3:40 pm 342g, 5°C Sea to Summit £255
I think I'll up my budget on the sleeping bag. Ultimately I can afford to do so and think it would be a good investment to minimise size and weight, as you said. I'll do some Googling on these three. I'm guessing that the most expensive is the "best" but I was curious as to why the comfort is "only" 5C compared to cheaper other branded items. I guess it's purely that compromise of size vs temperature.
space.gamer wrote: ↑Mon Oct 03, 2022 7:38 pm
There is no universally agreed standard for sleeping bag temperatures. Some manufacturers do quote one eg "ISO EN: Comfort: -2°C (28°F), Limit: -9°C (17°F), Extreme: -27°C (-17°F)". https://www.snowandrock.com/p/rab-ascen ... colour=108
In my opinion that bag is overkill for your purposes, and too heavy and too bulky.
In theory you could quote a tog rating. But there are so many other variables, manufacturers don't do this. So some quote one or two temeratures like 'comfort' and 'extreme'. Others quote 'typical operating temperature'. Some don't give a temperature. One manufacturer's 'comfort 5°' might be amother manufactuer's 10°. You can look into fill material, fill weight, fill quality (fillpower), inner and outer material, construction (box wall is way better than sewn-through), is it thicker on top.
Different tests, maybe different levels of trustworthiness. I would go with a brand used by most serious backpackers, ie one on ultralightoutdoorgear (or another site used by climbers), plus they are great for info. You don't have to buy it from there.
Down will pack smaller, be warmer and lighter. Yes, it fails if wet. But who gets their sleeping bag wet? Especially as you are getting a 2 skin tent. I would say for your purposes, comfort of 5° is easily good enough IF FROM A REPUTABLE MANUFACTURER. All it means is that if it is 1°, you won't sleep as well, might feel a bit cold. So you wear your winter base layer top, your puffy jacket or fleece, your longjohns and wool hiking socks. I carry thin wool socks as well, plus an old pair of thick ones that stretched, so I can wear all 3.
If you want synthetic, look for Primaloft Gold, it packs small and is warm.
This site will be out of your price range probably, but there is a lot of technical info on this page: https://www.phdesigns.co.uk/technical-briefings
Here are some other sites
https://www.cotswoldoutdoor.com/
Have you thought about cooking gear? I carry a 1.1 litre titanium mug/pot (aluminium is just as good for a gas stove). Inside it is a small gas canister (NB those prices are excellent!) and a canister-top stove (Soto Windmaster, cheaper ones are available of course, and also remote ones with a tube, which are a bit heavier and bulkier but more stable and easier to shield from the wind). Also I have a plastic canister stabaliser. This would be enough for a few freeze dried back packing meals, I only carry maybe two large meals that can be split using heavy duty stand-up freezer bags capable of taking boiling water. I also have some long life lifeboat survival ration bars.
At a push, you could strap your sleeping bag onto your rucksack, but it's better inside, squashed down at the bottom. Tent is better outside. Don't store your sleeping bag long term like this, Keep it loose, outside. When bugging out, don't roll it up, just stuff it in loose, then squash it down with other stuff. Rolled up it would take up more space and not fit the sack efficiently. Of course you need to test this first, make sure you can fit everything in. You can buy ultralight dry bags and sack liners. A sack liner is easier to fill efficiently. You can just use plastic rubble bag. Some drybags have valves to get the air out but they still take up more space than using a sack liner and stuffing everything in loose. This is because you always get wasted spaces around bulky items like filled drybags or rolled up sleeping bags.
space.gamer
Frnc wrote: ↑Tue Oct 04, 2022 7:16 amHave you thought about cooking gear? I carry a 1.1 litre titanium mug/pot (aluminium is just as good for a gas stove). Inside it is a small gas canister (NB those prices are excellent!) and a canister-top stove (Soto Windmaster, cheaper ones are available of course, and also remote ones with a tube, which are a bit heavier and bulkier but more stable and easier to shield from the wind). Also I have a plastic canister stabaliser. This would be enough for a few freeze dried back packing meals, I only carry maybe two large meals that can be split using heavy duty stand-up freezer bags capable of taking boiling water. I also have some long life lifeboat survival ration bars.
My backpacks are arriving today so I’ve decided I’ll start packing them up and play around with the space I’ve got. For example, I’ve got a few very cheap sleeping bags of various sizes so I can use them to determine whether I’m limited by volume or not. It might help me reinforce I need something as small as possible even if there’s some compromise on efficiency.
For a stove, I was thinking of something like a Vango Folding Camping Stove With Windshield and Piezo Ignition https://amzn.eu/d/bSF35IZ. It I’ve seen more self-contained ones that might suit.
To add to that, obviously you want to be able to bug out in a matter of minutes. But if you store a sleeping bag squashed down for years you'll ruin it. So you'll need to tip your sack out, stuff it in the bottom, and quickly re-pack the main compartment. On that note, I guess you want to buy from somewhere that a lot of people use, so you don't get a bag that's been stored compressed for too long.
Im my case, my sleeping bag is only just bigger than my fist when compressed, so I keep it uncompressed in an ultralight dry bag (Exped ULTRALIGHT Red 8 litres, 20g). If I have to bug out I'll squash it down, with the dry bag top just folded over so the air can squeeze out.
Also, make sure to note the width of the sleeping bag at shoulders, hips and feet. Last time I slept in one, I was 3 stone heavier and I found it a bit claustrophobic and annoying. Part of the reason I went for a half bag. Also I sleep hot. You probably want a zip that goes 3/4 of the way down. Personally I don't like having my feet trapped in a narrow bag, but for bugout purposes you can't be too fussy.
space.gamer
Frnc wrote: ↑Tue Oct 04, 2022 8:23 am Also, make sure to note the width of the sleeping bag at shoulders, hips and feet. Last time I slept in one, I was 3 stone heavier and I found it a bit claustrophobic and annoying. Part of the reason I went for a half bag. Also I sleep hot. You probably want a zip that goes 3/4 of the way down. Personally I don't like having my feet trapped in a narrow bag, but for bugout purposes you can't be too fussy.
Totally! That's why I fancy the look of the BIG AGNES Torchlight UL 20 Down Sleeping Bag https://ultralightoutdoorgear.co.uk/tor ... eping-bag/ as it has expandable sides and a foot area-thingy. But as I think you've said before, it's quite heavy, at 1.025kg.
Actually, looking again, they have a "UL 30" which is a bit cheaper and weights in at 840g. Again I know it's not superlight but with a quoted Comfort Limit of -1C, that could be an option. https://ultralightoutdoorgear.co.uk/tor ... eping-bag/. £330 each though :o but ultimately I'd rather pay more for something I like than save £100 on something I'm not happy with.
(Edit: there are some cheaper prices on different web sites, so I could definitely save some £ (e.g. https://wildbounds.com/products/torchli ... xUQAvD_BwE is almost £100 cheaper each bag - as long as shipping isn't extra :P ). If I can work with 840g and a compressed size of 13x15cm, then might be the one!)
Buying a sleeping bag is hard! Who knew?!
