We've got the swedish army trangia set but I'm not a fan to be honest, yes they work really well in the cold but I hate the messing about with paraffin, for some reason I aways end up stinking of the stuff.
These days my stove of choice for normal camping is one of those tiny folding gas stoves, I can get the stove and cannister inside a standard mess tin (and it's light) That said I do carry the old hexy "tommy cooker" as a back up.
What's the best cold weather camping sytem
Re: What's the best cold weather camping sytem
So its looking like whatever system(s) we use, we like a hexy as backup.
It's pretty well foolproof, and it works in the cold, the only issue is it smells a bit, but not as bad as I do after using paraffin.......Deeps wrote:So its looking like whatever system(s) we use, we like a hexy as backup.
At least you've got the paraffin excuse, I don't use paraffin but still smell.sniper 55 wrote:It's pretty well foolproof, and it works in the cold, the only issue is it smells a bit, but not as bad as I do after using paraffin.......Deeps wrote:So its looking like whatever system(s) we use, we like a hexy as backup.
I've not used proper hexy tabs for years (run out long ago) but use a civvy equivalent and also make my own which take longer to heat but stay lit longer. I take both with me in a tupaware type box.
Ohhh, whats the "recipe" Deeps? sounds like a project for a winters evening. And I'm getting low on originals as well mate.Deeps wrote:At least you've got the paraffin excuse, I don't use paraffin but still smell.sniper 55 wrote:It's pretty well foolproof, and it works in the cold, the only issue is it smells a bit, but not as bad as I do after using paraffin.......Deeps wrote:So its looking like whatever system(s) we use, we like a hexy as backup.
I got an old icecube container (holds 16 I think) and ripped up a couple of cotton wool balls and pushed them into each cube. Melted a good size candle and poured the wax into the cubes, gave them a good old push around to get rid of any bubbles and left them to set. Voila, they are quite smoky compared to the bought ones but I did a timed test on a bought one (stood on its end) and it didn't quite boil 500ml before dying after about 8 minutes. The homemade jobs took about 11 minutes (I think) and burned a good bit longer. I think I posted it somewhere on here, I'm starting to doubt myself now. Cover me, I'm going in for a recce....
Most portable gas stoves will work with Cylinders (the big ones you exchange full of butane, propane or mixes) as long as you do have the right Regulatorpeejay wrote:Indeed.
Is it the case that you can use just about any burner (not sure if that's the right term for the 'ot bit) with any gas canister/cylinder, providing you have the correct regulator, or are there certain burners that can't/don't/shouldn't work with certain cylinder types?
Camping stoves use Canisters and again you need the correct fitting to connect them.
I haven't yet found a way to safely use Canisters on a portable stove..... However, I'm sure there is a gadget for doing just that.
Just to clarify:
This is a portable stove.
And this is what I mean by a Camping stove
A camping stove that uses propane liquid take-off is the least likely gas stove to be affected by cold.
Liquid fuels (Petrol, Paraffin, Naptha and Alcohol) are less affected then gas as they are either un-pressurised (like chaffing gel or a Benghazi Burner) or are pressurised by the stove (Primas, Trangia, Pop-can, Supercat)
I hate the smell of Hexi and so use Alcohol (Pop-can) or Wood (Hobo) most of the time (I do carry Hexi, but thats as a 'need-fire-now' thing and then I'd use it as a quick fire-lighter rather then a fuel in itself).
I've got a scrap-wax burner in the kit too
Here's what I posted after testing.......Deeps wrote:Thanks to the wonders of youtube...sniper 55 wrote:
Off on a bit of a tangent (and re-resurrecting an old thread) but having watched some dudes on youtube make fuel blocks for hexy stoves and the like I thought I'd give it a go. Definitely falls into the dirt cheap category.
Basically, get an ice cube holder, fluff up a couple of cotton wool balls (and pull them apart a bit) and put 2 in each cube. Melt a candle and pour the wax over the cotton balls.
That's it, simples. I did a time test on a hexy tab V home made on 500ml cold water in a mess tin. It was a Highlander tab and definitely caught fire easier and heated up quicker, 1 tab stood on its side lasted about 8 minutes and the water wasn't quite boiling but hot enough for tea coffee and was after about 5 or 6 mins. The home made block took a bit of lighting and longer to heat the water but after 10 minutes it was boiling away and gave out a lot of flame/heat for 16 minutes. Downside was that it was very sooty and I'm not looking forward to cleaning the mess tin but for the price of a candle and some cotton balls its a goer and I'll be carrying both, even if its to use in combination.
They're different to the vaseline soaked pads, they take a bit more lighting, a bit more than the blocks too but they work well and cost buttons.
Thats for that mate, I'm going to be digging out some old candles later.
- Briggs 2.0
I've been living in a caravan and sleeping in a tent for a few months and life is made almost bearable by the Jetboil. I don't think there's much out there that can get 500ml boiled in such a quick time. Handy for a rapid cuppa and also good for boil in the bag food.
Off-Grid & Living Outdoors
